[GRASS-user] Some questions about d.vect and d.rast
Moritz Lennert mlennert at club.worldonline.be
Fri Apr 29 05:34:32 EDT 2011
On 29/04/11 00:37, Hamish wrote:
> Johannes wrote:
>> First I've two general questions about d.vect:
>> 1) Is it possible to use own symbol for the point icons?
> see
>   http://grass.osgeo.org/wiki/IconSymbols#Authoring_instructions
>> 2) How can I change the line type (e.g dashed line, etc.)?
> You can't. (only in ps.map)
> Maybe it will be possible in grass7?
One possible option (although admittedly somewhat brute force) is to use
v.to.points, playing with the dmax parameter in v.to.point or with the
symbol size to differentiate.
You can only use symbols that are the same in all directions (e.g.
circles) since the orientation of the symbol will not follow the
orientation of the line.
See attached screenshots based on the North Carolina demo data
roadsmajor map.
Moritz
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110429/9a1c0c7b/different_dmax_same_symbol_size-0001.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110429/9a1c0c7b/same_dmax_different_symbol_size-0001.png
