[GRASS-user] Question about r.out.gdal (netcdf format)
    Thomas Adams
    Thomas.Adams at noaa.gov
    Fri Aug  5 18:36:37 EDT 2011
  All:
I'm successfully able to export a netcdf file from GRASS 6.4.1 using
r.out.gdal. Using ncdump shows a reasonable result. The problem I'm
having is that the netcdf file contains neither the data type (2-m
temperature) nor the units (degrees Kelvin). The software I need to use
to import the resulting netcdf file must know the data type and units in
order to import it. How can I add these attributes to the netcdf file?
One thought I had was to use ncdump to export a cdl file and then have a
script add the attributes I need and then use ncgen to re-generate the
netcdf file with the data type and units attributes added.
Before I embarked on this path I thought there may be a simpler way? I
know there are tools such as cdo and ncl, but it may be more work to
sort-out using these than using the brute force method I'm proposing…
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
