[GRASS-user] Re: GRASS GIS Web UI
Jachym Cepicky jachym.cepicky at gmail.com
Thu Aug 18 06:49:56 EDT 2011
Does it use WPS, or some properitary protocol?
Jachym
2011/8/10 Mohammed Rashad <mohammedrashadkm at gmail.com>:
> On Fri, Aug 5, 2011 at 9:46 PM, Mohammed Rashad <mohammedrashadkm at gmail.com>
> wrote:
>> Hi all,
>> Here is GRASS GIS Web UI connected with OpenLayers widget
>> http://lsi.iiit.ac.in/lsi/wgrass
> in case this link is not working please use this
> http://lsi.iiit.ac.in:9090/wgrass
>> The app is under development and is released for initial testing. For
>> testing purpose we fix a lat/lont location and concentrate on vector data
>> Location Info:
>>    extent -180,-90,180,90
>>    mapset PERMANENT
>> you can import any grass vector data using v.in.ogr and display it in OL
>> using d.vect
>> For Listed GRASS modules:
>> 1. Type on search box on top for list and select a module and hit enter or
>> click search
>> 2. you will get a menuForm of the selected GRASS module.
>> 3. Fill all the attributes and click run to execute the grass module.
>> You can also run any grass command v.* or r.* using this webUI which is
>> unlisted
>> please test it....
>> Any comments, suggestions, BUGS are always welcomed..
>> Thanks && Regards
>> Rashad
> Thanks && Regards
> Rashad
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
