[GRASS-user] Re: GRASS GIS Web UI
Mohammed Rashad
mohammedrashadkm at gmail.com
Wed Aug 10 11:31:04 EDT 2011
On Fri, Aug 5, 2011 at 9:46 PM, Mohammed Rashad
<mohammedrashadkm at gmail.com>wrote:
> Hi all,
> Here is GRASS GIS Web UI connected with OpenLayers widget
> http://lsi.iiit.ac.in/lsi/wgrass
in case this link is not working please use this
http://lsi.iiit.ac.in:9090/wgrass
> The app is under development and is released for initial testing. For
> testing purpose we fix a lat/lont location and concentrate on vector data
> Location Info:
> extent -180,-90,180,90
> mapset PERMANENT
> you can import any grass vector data using v.in.ogr and display it in OL
> using d.vect
> For Listed GRASS modules:
> 1. Type on search box on top for list and select a module and hit enter or
> click search
> 2. you will get a menuForm of the selected GRASS module.
> 3. Fill all the attributes and click run to execute the grass module.
> You can also run any grass command v.* or r.* using this webUI which is
> unlisted
> please test it....
> Any comments, suggestions, BUGS are always welcomed..
> Thanks && Regards
> Rashad
Thanks && Regards
Rashad
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110810/39d3f4ee/attachment.html
