[GRASS-user] GRASS GIS Web UI
Mohammed Rashad
mohammedrashadkm at gmail.com
Fri Aug 5 12:16:30 EDT 2011
Hi all,
Here is GRASS GIS Web UI connected with OpenLayers widget
http://lsi.iiit.ac.in/lsi/wgrass
The app is under development and is released for initial testing. For
testing purpose we fix a lat/lont location and concentrate on vector data
Location Info:
extent -180,-90,180,90
mapset PERMANENT
you can import any grass vector data using v.in.ogr and display it in OL
using d.vect
For Listed GRASS modules:
1. Type on search box on top for list and select a module and hit enter or
click search
2. you will get a menuForm of the selected GRASS module.
3. Fill all the attributes and click run to execute the grass module.
You can also run any grass command v.* or r.* using this webUI which is
unlisted
please test it....
Any comments, suggestions, BUGS are always welcomed..
Thanks && Regards
Rashad
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110805/b7c406d0/attachment.html
