[GRASS-user] NVIZ - problem display 3D polygon (v.extrude
polygons)
Markus Neteler
neteler at osgeo.org
Tue Aug 16 05:58:53 EDT 2011
On Sat, Aug 6, 2011 at 9:24 PM, DelphineJB <del_cadarn at hotmail.com> wrote:
> Bonjour,
> I do apologise for this problem it must have been posted before but I
> couldn't get an answer in the archive.
> I am having problems to see vectors I have added height to with v.extrude .
> The trick is that I am actually using the e.g. given in NETELER, M and H.
> MITASOVA /Open Source GIS a GRASS GIS Approach/ with the North Carolina
> sample data. So in theory, this example should really be working...
> Here is what I did
> g.region rast=el_D792_6m -p
> v.extract P079215 out=bldg_resid_a where="layer='BLDG_RESID_BL'"
> v.extract P079215 out=bldg_cmcl_a where="layer='BLDG_COMMER_BL'"
There was an omission in that part of the book:
http://www.grassbook.org/errata_menu3rd.php
You need to convert the vector types first.
> v.extrude -t bldg_resid_a out=bldg_resid_a_3d height=10 elev=el_D792_6m
> v.extrude -t bldg_cmcl_a out=bldg_cmcl_a_3d height=15 elev=el_D792_6m
> g.region rural_1m -p
> nviz elev_lid792_1m col=ortho_2001_t792_1m
> vect=bldg_resid_a_3d,bldg_cmcl_a_3d
> I am using Grass 6.4.1 with the python GUI on Windows 7
> Now the infamous result is just some line on what should be the height of
> the building, like if NVIZ read it as lines rather than 3D surface...
With the correction, it will work.
Markus
