[GRASS-user] v.net.path problem (not the shortest route)
    Jorge de Jesus
    jmdj at pml.ac.uk
    Fri Aug 19 06:21:40 EDT 2011
 Hi to all
As usual it was something simple that I've missed :-) .... and of course
v.net.path (in GRASS70) was correct
v.clean in=graph out=graph_clean tool=break,rmdupl
did the trick to fix the graph and put everything in order (even the cat
field was missing)
The graph was actually prepared in QGIS, and I should have imported it
into GRASS and check the graph
THANKS, I own you a beer
Jorge
On 19/08/11 10:29, Markus Metz wrote:
> On Fri, Aug 19, 2011 at 11:16 AM, Jorge de Jesus <jmdj at pml.ac.uk> wrote:
>>  Hi to all
>> I've a question concerning v.net.path. I am probably missing something
>> obvious :-[
>> In the v.net.path example that I've posted yesterday
>> (http://rsg.pml.ac.uk/wps/example/index.html), if we put the car over
>> madrid and the destination in the node below Santa Maria (below Porto
>> city), the v.net.path uses a different route going thru Vigo. Therefore
>> picking a route that isnt the shortest.
> There were problems with the v.net.* modules in GRASS 6.4.0, maybe
> also in 6.4.1. The v.net.* modules should be working correctly in
> 6.4.2, 6.5, and 7. Just in case you're using an older version of
> GRASS.
> Can you post 1) the full v.net command used to prepare the network, 2)
> the output of v.net op=report, 3) the full v.net.path command? This
> information should help to track down the problem.
> Markus M
Plymouth Marine Laboratory
Registered Office:
Prospect Place
The Hoe
Plymouth  PL1 3DH
Website: www.pml.ac.uk
Click here for PML Annual Review
Registered Charity No. 1091222
PML is a company limited by guarantee
registered in England & Wales
company number 4178503
Please think before you print
This e-mail, its content and any file attachments are confidential.
If you have received this e-mail in error please do not copy, disclose it to any third party or use the contents or attachments in any way. Please notify the sender by replying to this e-mail or e-mail forinfo at pml.ac.uk and then delete the email without making any copies or using it in any other way.
The content of this message may contain personal views which are not the views of Plymouth Marine Laboratory unless specifically stated.
You are reminded that e-mail communications are not secure and may contain viruses. Plymouth Marine Laboratory accepts no liability for any loss or damage which may be caused by viruses.
