[GRASS-user] Re: winGrass and v.distance error
Helmut Kudrnovsky
hellik at web.de
Tue Aug 23 07:58:46 EDT 2011
hi,
>v.distance from=txtloc at PERMANENT to=RA at PERMANENT to_type=line,area
upload=cat column=cat to_column=RA_CODE
try to choose another column than "cat",
I've tested with the nc-sample-dataset by
WinGRASS-6.4.SVN-r47802-1-Setup.exe:
g.copy vect=bridges at PERMANENT,mybrigdes
g.copy vect=lakes at PERMANENT,mylakes
v.db.addcol map=mybridges at g7 columns="areacat INT"
v.distance --overwrite --verbose from=mybridges at g7 to=mylakes at g7
to_type=area upload=cat column=areacat
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/winGrass-and-v-distance-error-tp6714285p6715880.html
Sent from the Grass - Users mailing list archive at Nabble.com.
