[GRASS-user] Re: winGrass and v.distance error
Sharon M
morrisxs09 at gmail.com
Fri Aug 26 02:53:14 EDT 2011
Apologies for delay in responding.
It doesn't matter whether I choose the cat column or another attribute
column, the same issue occurs.
l haven't had a chance to test using the NC data however before raising the
issue I did test using spearfish and the "fields" and "archsites" maps -
this worked, but there are only 25 records.
What I did discover when aborting the v.distance command *and *closing
winGrass is it finally wrote the data to the dbf file. It seems the command
had to be aborted and winGrass shutdown, then the data was written out - I
hope this gives someone a lead on the issue.
Sharon
On Tue, Aug 23, 2011 at 9:28 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> >v.distance from=txtloc at PERMANENT to=RA at PERMANENT to_type=line,area
> upload=cat column=cat to_column=RA_CODE
> try to choose another column than "cat",
> I've tested with the nc-sample-dataset by
> WinGRASS-6.4.SVN-r47802-1-Setup.exe:
> g.copy vect=bridges at PERMANENT,mybrigdes
> g.copy vect=lakes at PERMANENT,mylakes
> v.db.addcol map=mybridges at g7 columns="areacat INT"
> v.distance --overwrite --verbose from=mybridges at g7 to=mylakes at g7
> to_type=area upload=cat column=areacat
> Helmut
> http://osgeo-org.1803224.n2.nabble.com/winGrass-and-v-distance-error-tp6714285p6715880.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110826/dbf4b15e/attachment.html
