[GRASS-user] Map algebra maximum value
Markus Metz
markus.metz.giswork at googlemail.com
Tue Aug 23 08:28:00 EDT 2011
On Tue, Aug 23, 2011 at 1:40 PM, Salvatore Mellino
<salvatore.mellino at gmail.com> wrote:
> Hi,
> I have a problem, I have 4 rasters for the same region, I want to generate another raster that contains only the maximum value for each cell and I want to know from which starting raster it comes. It is possible? Which is the command?
r.series in=map1,map2,map3,map4 out=map_maxval,map_maxrast
method=maximum,max_raster
should do the trick in one go. map_maxval will hold the maximum value,
map_maxrast the number of the raster with the maximum value, dependent
on the order of input to r.series.
Markus M
