[GRASS-user] GRASS windows cmd run issue
Rebecca Bennett
rabennett at ymail.com
Mon Aug 29 09:46:29 EDT 2011
Hello all
I have a problem getting GRASS to run on windows having downloaded through the OSGeo4W installer (quick install). GRASS works prefectly through QGIS (including shell commands) but fails to load from the shortcuts or start menu. Unfortunately the shell drops out immediately so I am unable to read exactly what the problem is but I think that it might be unable to find the init file in the specified location.
I am currently not working on my own computer but in a computer lab (in Italy) so to the best of my knowledge the set up is as follows:
GRASS 6.4.1
Windows 7 (with admin rights ,not sure if 32 or 64bit)
If anyone has come across this issue before or has any ideas to resolve it I (and my students) would be very grateful to hear from you!
Thanks for reading,
Rebecca Bennett
Postgraduate Researcher (Archaeology Group)
Bournemouth University
Mode 2: integrated daily irradiation for a given day of the year
>^C 0%
>Il giorno 24/ago/2011, alle ore 13:37, Markus Neteler ha scritto:
>> On Wed, Aug 24, 2011 at 12:21 PM, Salvatore Mellino
>> <salvatore.mellino at gmail.com> wrote:
>>> Hi,
>>> I want to generate a cumulative annual map for solar radiation (W/m2/yr). It
>>> is possible with r.sun? There is a script to do this?
>> You can find a ascript here:
>> http://www.grassbook.org/examples_menu2nd.php
>> -> rsun_crop.sh
>> If you have complex terrain, you will want to add the "-s" flag for the shadow
>> correction.
>> Markus
>_______________________________________________
>grass-user mailing list
>grass-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110829/a2d2e942/attachment.html
