[GRASS-user] GRASS windows cmd run issue
Maris Nartiss maris.gis at gmail.com
Mon Aug 29 11:26:16 EDT 2011
Hello,
no idea where the problem could be.
Here are some steps to try to get more information:
1) right click one of launcher icons and find out GRASS location;
2) run cmd.exe
3) cd to GRASS installation directory
4) type in GRASS startup script name (see step 1)
5) google for error message
6) fiddle around more
7) install GRASS nightly from http://wingrass.fsv.cvut.cz/grass64/
8) fall into despair as nothing works
9) remove Windows and replace it with GNU/Linux
10) just to find out that YOURDISTROCHOICE packages are broken
11) go to nearest bar to take a few shots of whiskey - only thing that works.
Just follow those steps as long as You want to. You can stop after 5th
one and return to ML too.
Maris.
2011/8/29 Rebecca Bennett <rabennett at ymail.com>:
> Hello all
> I have a problem getting GRASS to run on windows having downloaded through
> the OSGeo4W installer (quick install). GRASS works prefectly through QGIS
> (including shell commands) but fails to load from the shortcuts or start
> menu. Unfortunately the shell drops out immediately so I am unable to read
> exactly what the problem is but I think that it might be unable to find the
> init file in the specified location.
> I am currently not working on my own computer but in a computer lab (in
> Italy) so to the best of my knowledge the set up is as follows:
> GRASS 6.4.1
> Windows 7 (with admin rights ,not sure if 32 or 64bit)
> If anyone has come across this issue before or has any ideas to resolve it I
> (and my students) would be very grateful to hear from you!
> Thanks for reading,
> Rebecca Bennett
> Postgraduate Researcher (Archaeology Group)
> Bournemouth University
> Mode 2: integrated daily irradiation for a given day of the year
> ^C 0%
> Il giorno 24/ago/2011, alle ore 13:37, Markus Neteler ha scritto:
>> On Wed, Aug 24, 2011 at 12:21 PM, Salvatore Mellino
>> <salvatore.mellino at gmail.com> wrote:
>>> Hi,
>>> I want to generate a cumulative annual map for solar radiation (W/m2/yr).
>>> It
>>> is possible with r.sun? There is a script to do this?
>> You can find a ascript here:
>> http://www.grassbook.org/examples_menu2nd.php
>> -> rsun_crop.sh
>> If you have complex terrain, you will want to add the "-s" flag for the
>> shadow
>> correction.
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
