[GRASS-user] How to find the second largest value in a series of
	rasters.
    Marcello Gorini
    gorini at gmail.com
    Thu Dec  8 15:30:39 EST 2011
Dear all,
I have to find the maximum value for each cell in a series of rasters and
generate both a maximum value map and a categorical map with the raster
number which contains the maximum value.
R.series is, therefore, perfect to accomplish that using
method=maximum,max_raster.
My problem is that I also need to find the *second largest* value and the
corresponding raster number which contains the second largest value.
I am doing that by iterating over all classes through a shell script, but it
obviously takes much more time than using a simple r.series command.
Can anyone share any idea on how to accomplish that using r.series or
something similar?
Thanks in advance for your thoughts.
Best regards,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-find-the-second-largest-value-in-a-series-of-rasters-tp7075764p7075764.html
Sent from the Grass - Users mailing list archive at Nabble.com.
