[GRASS-user] Problems to launch QGIS from GRASS
    Markus Neteler
    neteler at osgeo.org
    Sun Dec 11 08:19:33 EST 2011
2011/12/10 José Carlos Guerrero Antúnez <jcgantunez at gmail.com>:
> Hi,
> When I try to launch QGIS (1.7.2) from within GRASS, I receive the
> following:
> bash: qgis: command not found
> Welcome to GRASS 6.4.1 (2011)
> GRASS homepage:                          http://grass.osgeo.org/
> This version running thru:               Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the GUI with:       g.gui tcltk
> When ready to quit enter:                exit
> GRASS 6.4.1 (Sudamérica):~ > qgis
Please check the path to QGIS from where you commonly start it.
That may be the menu or elsewhere. If the path in not listed
in the $PATH variable, then please post it here and also the output
of
echo $PATH
from *within* a GRASS session. Then it will be easy to solve that.
Markus
