[GRASS-user] Problems to launch QGIS from GRASS
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Sun Dec 11 19:50:33 EST 2011
Hi Markus,
When I check the echo $PATH from within GRASS session, this is the message,
GRASS 6.4.1 (spearfish60):~ > echo $PATH
Applications/GRASS-6.4.app/Contents/MacOS/bin:/Applications/GRASS-6.4.app/Contents/MacOS/scripts:/Users/joseca/Library/GRASS/6.4/Modules/bin:/Library/GRASS/6.4/Modules/bin:/Library/Frameworks/GDAL.framework/unix/bin:/Library/Frameworks/PROJ.framework/Programs:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
GRASS 6.4.1 (spearfish60):~ > qgis
bash: qgis: command not found
I do not know how to solve it but I am very grateful to your help.
Jose Guerrero
El 11 de diciembre de 2011 11:19, Markus Neteler <neteler at osgeo.org>escribió:
> 2011/12/10 José Carlos Guerrero Antúnez <jcgantunez at gmail.com>:
> > Hi,
> > When I try to launch QGIS (1.7.2) from within GRASS, I receive the
> > following:
> > Welcome to GRASS 6.4.1 (2011)
> > GRASS homepage: http://grass.osgeo.org/
> > This version running thru: Bash Shell (/bin/bash)
> > Help is available with the command: g.manual -i
> > See the licence terms with: g.version -c
> > If required, restart the GUI with: g.gui tcltk
> > When ready to quit enter: exit
> > GRASS 6.4.1 (Sudamérica):~ > qgis
> Please check the path to QGIS from where you commonly start it.
> That may be the menu or elsewhere. If the path in not listed
> in the $PATH variable, then please post it here and also the output
> of
> echo $PATH
> from *within* a GRASS session. Then it will be easy to solve that.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111211/5937d07a/attachment.html
