[GRASS-user] r.in.gdal, doesn't import raster image
José Carlos Guerrero Antúnez jcgantunez at gmail.com
Mon Dec 12 21:16:06 EST 2011
Hello,
Thank you very much for your help, now I can launch Qgis from within GRASS.
But I have the following problem with a raster image that I can not import
it. This image comes from Maxent software.
And I follow the below procedure in GRASS:
- File, Import raster map, Multiples format using GDAL by r.in.gdal
Required: Raster file to be imported
               Name for output raster map
And this is the message from Output - GIS.m
Projection of dataset does not appear to match current location.
Location PROJ_INFO is:
proj: ll
datum: wgs84
ellps: wgs84
towgs84: 0,0,0,0,0,0,0
no_defs: defined
Import dataset PROJ_INFO is:
cellhd.proj = 0 (unreferenced/unknown)
You can use the -o flag to r.in.gdal to override this check and use the
location definition for the dataset.
Consider generating a new location from the input dataset using the
'location' parameter.
If I perform the procedure in qgis (the image can be displayed correctly), I
have no successfully.
Sorry, I'm not a trained person in programming.
Thanks,
José Guerrero
El 12 de diciembre de 2011 00:36, William Kyngesburye <woklist at kyngchaos.com
> escribió:
> On Dec 11, 2011, at 7:19 PM, Hamish wrote:
> > José wrote:
> >> When I check the echo $PATH from within GRASS
> >> session, this is the message,
> >> GRASS 6.4.1 (spearfish60):~ > echo $PATH
> /Applications/GRASS-6.4.app/Contents/MacOS/bin:/Applications/GRASS-6.4.app/Contents/MacOS/scripts:/Users/joseca/Library/GRASS/6.4/Modules/bin:/Library/GRASS/6.4/Modules/bin:/Library/Frameworks/GDAL.framework/unix/bin:/Library/Frameworks/PROJ.framework/Programs:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
> >> GRASS 6.4.1 (spearfish60):~ > qgis
> >> bash: qgis: command not found
> >> I do not know how to solve it but I am very
> >> grateful to your help.
> > ah ok, this is a Mac.
> > first thing to do is to hunt down the qgis executable and get it into
> one of the $PATH directories.
> > try like:
> > ls -l /Applications/QuantumGIS.app/Contents/MacOS/
> > and look for a qgis file (not directory) with "x" permissions.
> > once you have that make a symlink into /usr/local/bin
> > ln -s /Applications/QuantumGIS.app/Contents/MacOS/qgis /usr/local/bin/
> > you might have to put "sudo" before the symlink to get it to work.
> > (not sure of exact qgis pathnames, but something
> > similar to the above)
> I was wondering if you were on OS X...
> Note that this symlink method really isn't the proper way to start an
> *application* on OS X.  Running an application from the command line in the
> standard *nix execute way ignores existing running processes, and will
> start another if one is already running.
> The simplest solution is to just start Qgis the normal way by
> double-clicking the application.
> If you really must start it from within GRASS, then the OS X way is to
> "open" applications:
> open -a QGIS.app
> There is no need to symlink QGIS to /usr/local/bin, and no need to know
> the path to QGIS.app.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers exactly what
> the universe is for and why it is here, it will instantly disappear and be
> replaced by something even more bizarrely inexplicable.  There is another
> theory which states that this has already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
Dr. José Carlos Guerrero
Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
(LDSGAT)
Instituto de Ecología y Ciencias Ambientales (IECA)
Facultad de Ciencias
Universidad de la República
Montevideo-URUGUAY
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111213/d7446a95/attachment.html
