[GRASS-user] Re: r.in.gdal, doesn't import raster image
Stefan Sylla
stefansylla at gmx.de
Tue Dec 13 02:35:43 EST 2011
>Projection of dataset does not appear to match current location.
>Location PROJ_INFO is:
>proj: ll
>datum: wgs84
>ellps: wgs84
>towgs84: 0,0,0,0,0,0,0
>no_defs: defined
>Import dataset PROJ_INFO is:
>cellhd.proj = 0 (unreferenced/unknown)
Well, it looks like your raster image does not have projection information
in the metadata. If you are sure that the image is referenced to a latlong
grid on WGS84, then use the -o flag as proposed by r.in.gdal.
>- File, Import raster map, Multiples format using GDAL by r.in.gdal
>Required: Raster file to be imported
> Name for output raster map
In the r.in.gdal dialog click on 'Options' and select 'override projection
(use location's projection)'. That will do.
Hope this helps
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-in-gdal-doesn-t-import-raster-image-tp7088537p7089036.html
Sent from the Grass - Users mailing list archive at Nabble.com.
