[GRASS-user] v.sample value to db column
Johannes Radinger
JRadinger at gmx.at
Tue Feb 1 10:45:20 EST 2011
hej,
is it somehow possible to sample a raster map at given point locations, and put the values directly into a column of the db of the points?
I tried with
v.sample input=segment_points raster=stream_segments column=seg_num
but thats not working...
In following discussion, the same thing is mentioned:
http://wald.intevation.org/tracker/index.php?func=detail&aid=513&group_id=21&atid=205
but is there a simple solution? (I am using GRASS GIS 6.5)
thanks
Johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
