[GRASS-user] v.sample value to db column
Micha Silver
micha at arava.co.il
Tue Feb 1 11:44:58 EST 2011
On 02/01/2011 05:45 PM, Johannes Radinger wrote:
> hej,
> is it somehow possible to sample a raster map at given point locations, and put the values directly into a column of the db of the points?
v.what.rast
> I tried with
> v.sample input=segment_points raster=stream_segments column=seg_num
> but thats not working...
> In following discussion, the same thing is mentioned:
> http://wald.intevation.org/tracker/index.php?func=detail&aid=513&group_id=21&atid=205
> but is there a simple solution? (I am using GRASS GIS 6.5)
> thanks
> Johannes
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
