[GRASS-user] error
Markus Neteler
neteler at osgeo.org
Wed Feb 9 05:58:00 EST 2011
On Wed, Feb 9, 2011 at 11:19 AM, Sofina Natalia <nsofina at gmx.de> wrote:
> Hi, everybody!
> I receive an error If I try to delete a map "[tmrast at erdbeben@erdbeben] is a
> base map. Remove reclassed map first: MASK at erdbeben". But the MASK is
> already deleted, I haven't any MASK-maps... How can solve this problem?
I rarely run into the same (unexplained) problem.
If you use instead g.mremove on that map, it will work.
Markus
