[GRASS-user] Running GRASS 7 on ubuntu without GUI
Jon Britton
jonbritton3 at googlemail.com
Wed Feb 9 06:43:27 EST 2011
I've installed GRASS 7 on Ubuntu by compiling from source (trunk).
Everything seems to have gone fine during the compiling/installation
process, but I can't get it to run from the command line. When I try and
run it I get the following error:
WARNING: It appears that the X Windows system is not active.
A graphical based user interface is not supported.
Switching to text based interface mode.
Hit RETURN to continue
/usr/local/src/grass_trunk/<UNKNOWN>/<UNKNOWN>/.gislock: No such file or
directory
ERROR: /usr/local/grass-7.0.svn/etc/lock:
Unable to properly access
"/usr/local/src/grass_trunk/<UNKNOWN>/<UNKNOWN>/.gislock"
Please notify system personel.
I'm running this on a server, so don't have a GUI. Does this mean that
GRASS hasn't installed correctly?
Thanks,
Jon
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110209/bc010318/attachment.html
