[GRASS-user] Using vector data in Grass 6.4.0 on WinXP Pro
Paul Shapley
p.shapley at gmail.com
Fri Feb 11 08:31:29 EST 2011
I have a vector layer of 100000 polys and have noticed some odd behaviour.
There is a long delay of a couple of minutes on opening the attribute table
(i'm accessing (Postgresql/postgis locally at present). Also when the layer
is open applying a simple query in the attribute table manager fails to get
any results it just appears to freeze (not responding). It is does not zoom
to attribute like other layers but zooms out to map extent instead. I have
checked topology with v.build and it seems all okay.
Does anyone else get this with larger vector layers?
Paul J. Shapley
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110211/77af7645/attachment.html
