[GRASS-user] ESRI - Grass Equivalents
jaydub
justcallmejay at gmail.com
Mon Feb 21 12:25:32 EST 2011
Hi I'm trying to replicate some of the functionality in ESRI via GRASS.
I need to do a regularized spline with the following parameters:
weight = 0.1
points = 12
cell size = 100
So far I'm trying to use the v.sruf.rst to accomplish this. I'm not sure how
to match these values up with GRASS at all. Is the tension param similar to
weight? Grass uses segments and ESRI uses cells? How do I match up GRASS's
vars with esri's?
max/min number of points in a segment
min distance between points
max distance between points on isoline
conversion factor
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ESRI-Grass-Equivalents-tp6049458p6049458.html
Sent from the Grass - Users mailing list archive at Nabble.com.
