Fwd: [GRASS-user] Generate 3D raster from two surfaces
grass at sundquist.imapmail.org
Mon Feb 21 17:46:19 EST 2011
On Mon, 21 Feb 2011 21:40:44 +0100, "Soeren Gebbert"
<soerengebbert at googlemail.com> said:
> Hello,
> IMHO the result on the top of the volume data in paraview looks
> correct, because the top elevation map as lower values as 75ft at the
> NW side.
> I strongly recommend that you use the threshold filter and the cutting
> tools of paraview to have a deeper insight of the result.
Thanks. Forgot about the "threshold" suggestion. Works now.
I really appreciate your help on this.
J.S.
