[GRASS-user] r.mapcalc help
Chris Carleton w_chris_carleton at hotmail.com
Fri Feb 25 12:22:19 EST 2011
Hi List,
I'm writing a short python script that involves some mapcalc and I
could really use some more eyes on the problem. I'm not sure why I'm
getting the results that I am - might be that I'm confused about the
operation with isnull(). The input consists of two maps:
1. (let it be 'A') a circular area, derived from a v.buffer-v.to.rast
operation, that contains distances from r.grow.distance
2. (let it be 'B') a map of distances from r.grow.distance that covers
a much larger area than the buffer circle in map 1.
All of the buffer circles created are within the area covered by map B
and some of the map A circles may overlap one another. Below is some
pseudo-code with the mapcalc operation in actual code. So far, my
result at the end, which is essentially a distance map that has been
updated by the circles in map A, is just a map a nulls.
def main():
get cat values from a vector map
for i in cat_values:
v.extract -r cat value i
v.to.rast extracted_cats
r.grow.distance to rast_extracted_cats #essentially get the distances
to all points in vector while leaving out one at a time
v.extract cat_value i #to use as the center for a buffer operation
that will then be used to query the distance map created in the last
step
v.buffer with extracted_cat_i
v.to.rast extracted_cat_i
r.mapcalc if(extracted_cat_i,distance_map) #this step uses the buffer
area to mask the distance map and is now map 'A'
###the problematic r.mapcalc operation is below###
subprocess.call([
	"r.mapcalc",
	"B = if(!isnull(A) && temp_rast_focus_ <= B,A,B"])
return()
The idea is that each map A will be used to update B only if A is less
than (or equal to) B. It seems that the first run through the loop
creates a map B which is only the circle from map A, and then the
second run creates a null map B, which then of course stays null for
all further operations. Any suggestions here would be greatly
appreciated. Thanks,
Chris
