[GRASS-user] r.streams not compiling for GRASS 70
Stephen Sefick
ssefick at gmail.com
Fri Feb 25 18:17:08 EST 2011
also there is an error in the wxpython/docs I don't know if this is
known or not.
/home/ssefick/source/grass/grass7/gui/wxpython/docs
On Fri, 2011-02-25 at 23:09 +0100, Markus Neteler wrote:
> On Fri, Feb 25, 2011 at 9:41 PM, Stephen Sefick <ssefick at gmail.com> wrote:
> > 1. file from add-ons moved over to grass70 source tree in raster folder
> Not needed, you can compile directly from grass-addons/:
> cd grass-addons/grass7/raster/r.stream/r.stream.snap/
> make MODULE_TOPDIR=$HOME/grass70/
> if needed:
> make MODULE_TOPDIR=$HOME/grass70/ install
> to clean:
> make MODULE_TOPDIR=$HOME/grass70/ clean
> > Assembler messages:
> > Fatal error: can't create OBJ.x86_64-unknown-linux-gnu/io.o: No such
> > file or directory
> > make[1]: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
> > make[1]: Leaving directory
> > `/home/ssefick/source/grass/trunk/raster/r.stream/r.stream.snap'
> This error I don't get. I am using
> gcc version 4.4.3 (GCC)
> But there are a series of compiler warnings like
> main.c:126: warning: implicit declaration of function ‘create_distance_mask’
> main.c:127: warning: implicit declaration of function ‘read_points’
> main.c:130: warning: implicit declaration of function ‘snap_point’
> main.c:132: warning: implicit declaration of function ‘write_points’
> which should be fixed.
> Markus
