[GRASS-user] r.streams not compiling for GRASS 70
stephen sefick
sas0025 at auburn.edu
Fri Feb 25 19:28:20 EST 2011
Markus, Sorry for not posting this to the whole like. I hit reply and
not reply all. Here is the error for compiling GRASS7 and addons
r.stream.
svn up today
Error:
make MODULE_TOPDIR=$HOME/source/grass/grass7
gcc -g -Wall -Werror-implicit-function-declaration -fno-common -
Wextra -Wunused -I/home/ssefick/source/grass/grass7/dist.x86_64-
unknown-linux-gnu/include -I/home/ssefick/source/grass/grass7/
dist.x86_64-unknown-linux-gnu/include -D_FILE_OFFSET_BITS=64 -I/usr/
include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" -I/home/
ssefick/source/grass/grass7/dist.x86_64-unknown-linux-gnu/include -I/
home/ssefick/source/grass/grass7/dist.x86_64-unknown-linux-gnu/include
-o OBJ.x86_64-unknown-linux-gnu/io.o -c io.c
io.c: In function ‘ram_create_map’:
io.c:16: warning: format not a string literal and no format arguments
io.c:13: warning: unused variable ‘c’
io.c: In function ‘ram_read_map’:
io.c:139: warning: format not a string literal and no format arguments
io.c: In function ‘seg_create_map’:
io.c:278: warning: format not a string literal and no format arguments
io.c:282: error: implicit declaration of function ‘creat’
io.c:287: warning: format not a string literal and no format arguments
io.c:291: error: implicit declaration of function ‘open’
io.c:293: warning: format not a string literal and no format arguments
io.c:298: warning: format not a string literal and no format arguments
io.c: In function ‘seg_read_map’:
io.c:404: warning: format not a string literal and no format arguments
make: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
thanks
Stephen
On Feb 25, 2011, at 4:09 PM, Markus Neteler wrote:
> On Fri, Feb 25, 2011 at 9:41 PM, Stephen Sefick <ssefick at gmail.com>
> wrote:
>> 1. file from add-ons moved over to grass70 source tree in raster
>> folder
> Not needed, you can compile directly from grass-addons/:
> cd grass-addons/grass7/raster/r.stream/r.stream.snap/
> make MODULE_TOPDIR=$HOME/grass70/
> if needed:
> make MODULE_TOPDIR=$HOME/grass70/ install
> to clean:
> make MODULE_TOPDIR=$HOME/grass70/ clean
>> Assembler messages:
>> Fatal error: can't create OBJ.x86_64-unknown-linux-gnu/io.o: No such
>> file or directory
>> make[1]: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
>> make[1]: Leaving directory
>> `/home/ssefick/source/grass/trunk/raster/r.stream/r.stream.snap'
> This error I don't get. I am using
> gcc version 4.4.3 (GCC)
> But there are a series of compiler warnings like
> main.c:126: warning: implicit declaration of function
> ‘create_distance_mask’
> main.c:127: warning: implicit declaration of function ‘read_points’
> main.c:130: warning: implicit declaration of function ‘snap_point’
> main.c:132: warning: implicit declaration of function ‘write_points’
> which should be fixed.
> Markus
