[GRASS-user] using r.resamp.stats- When I reach a tie
Glynn Clements
glynn at gclements.plus.com
Sat Feb 26 00:45:32 EST 2011
António Rocha wrote:
> I'm planning on using r.resamp.stats in order to resample a grid to a
> coarser resolution. Since I'm using this function with classes I will
> use mode method (more frequentclass to fall into a destination cell is
> the chosen). My question is: when I have a tie between two classes, how
> does GRASS decides which class shall be chosen?
In the event of a tie, the lowest-numbered category is chosen.
