[GRASS-user] r.streams not compiling for GRASS 70
stephen sefick
sas0025 at auburn.edu
Sat Feb 26 09:56:14 EST 2011
I have svn up in both source directories and issue the command below
from within the r.stream.basins directory
make MODULE_TOPDIR=$a #(is where my grass7 source directory is)
gcc -g -Wall -Werror-implicit-function-declaration -fno-common -
Wextra -Wunused -I/home/ssefick/source/grass/grass7/dist.x86_64-
unknown-linux-gnu/include -I/home/ssefick/source/grass/grass7/
dist.x86_64-unknown-linux-gnu/include -D_FILE_OFFSET_BITS=64 -I/usr/
include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" -I/home/
ssefick/source/grass/grass7/dist.x86_64-unknown-linux-gnu/include -I/
home/ssefick/source/grass/grass7/dist.x86_64-unknown-linux-gnu/include
-o OBJ.x86_64-unknown-linux-gnu/io.o -c io.c
io.c: In function ‘ram_create_map’:
io.c:16: warning: format not a string literal and no format arguments
io.c:13: warning: unused variable ‘c’
io.c: In function ‘ram_read_map’:
io.c:139: warning: format not a string literal and no format arguments
io.c: In function ‘seg_create_map’:
io.c:278: warning: format not a string literal and no format arguments
io.c:282: error: implicit declaration of function ‘creat’
io.c:287: warning: format not a string literal and no format arguments
io.c:291: error: implicit declaration of function ‘open’
io.c:293: warning: format not a string literal and no format arguments
io.c:298: warning: format not a string literal and no format arguments
io.c: In function ‘seg_read_map’:
io.c:404: warning: format not a string literal and no format arguments
make: *** [OBJ.x86_64-unknown-linux-gnu/io.o] Error 1
I will help in any I can. Thanks in advance for all of your wonderful
help.
Stephen
On Feb 26, 2011, at 2:12 AM, Hamish wrote:
> Markus wrote:
>>> This error I don't get. I am using gcc version 4.4.3 (GCC)
>>> But there are a series of compiler warnings like
>>> main.c:126: warning: implicit declaration of function
>>> ‘create_distance_mask’
>>> main.c:127: warning: implicit declaration of function ‘read_points’
>>> main.c:130: warning: implicit declaration of function ‘snap_point’
>>> main.c:132: warning: implicit declaration of function ‘write_points’
>>> which should be fixed.
> function prototypes added to local_proto.h in r45462.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
