[GRASS-user] v.rast.stats2 bug?
Mark Seibel
mseibel at gmail.com
Mon Feb 28 20:02:09 EST 2011
I just checked out v.rast.stats2 (Feb.28) and when I run it I get the
following error.
Do I need to file a ticket, or am I missing something obvious? While
it says 'done', the table is unpopulated.
awk: {printf "\nUPDATE acoe_jd SET dist_n
awk: ^ unterminated string
sed: couldn't write 176 items to stdout: Broken pipe
Restoring previous MASK...
Statistics calculated from raster map <streams_distance_ft at PERMANENT>
and uploaded to attribute table of vector map <acoe_jd>.
Done.
Much thanks,
Mark
