[GRASS-user] leftover node in v.digit
Maciej Sieczka
msieczka at sieczka.org
Sun Jan 9 07:51:11 EST 2011
W dniu 08.01.2011 06:01, Shane Litherland pisze:
> Hi Maris,
> Have braved my first attempt at filing a bug report, and appear to have
> put enough together to generate a ticket
> Ticket #1256
> leftover node when deleting boundaries vertex-by-vertex
> hope it's of help... :-)
Shane,
6.4.0 RC6 is several months old.
Please try installing and veryfing your issues against the newest stable
release candidate - http://grass.osgeo.org/grass64/binary/linux/snapshot/.
If impossible, please at least try the 6.4.0 final Ubuntu package from
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable/.
Maciek
> -shane.
> On Fri, 2011-01-07 at 12:49 +0200, Maris Nartiss wrote:
>> Open a bug report with exact step-by-step how to reproduce this issue.
>> http://trac.osgeo.org/grass
>> Maris.
>> 2011/1/7, Shane Litherland<litherland-farm at bigpond.com>:
>>> Hi again,
>>> another little thing I found by accident,
>>> If digitising boundaries, then using 'remove vertex' to delete some of a
>>> boundary, vertex-by-vertex... If I kept going and removed all the
>>> vertexes (instead of the correct way of using 'delete
>>> point/line/boundary'), it was possible to end up with some leftovers..
>>> I could see a lone red cross on the v.digit screen (meaning, node(1
>>> line) ) that I could not select to move, add, delete, anything... no
>>> matter what my zoom.
>>> This errant node did not show in the GRASS map view of the vector in
>>> question, only in v.digit.
>>> Using v.clean 'found' and removed this errant node (using the rmline
>>> option) and I checked the vector info of the 'dirty' versus 'clean'
>>> vectors to see nothing else had been upset.
>>> It was an accident, I thought I'd selected the 'delete' tool...
>>> but interesting, nonetheless ;-)
>>> regards,
>>> shane.
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
Maciej Sieczka
http://www.sieczka.org
