[GRASS-user] leftover node in v.digit
Shane Litherland litherland-farm at bigpond.com
Sat Jan 8 00:01:45 EST 2011
Hi Maris,
Have braved my first attempt at filing a bug report, and appear to have
put enough together to generate a ticket
Ticket #1256
leftover node when deleting boundaries vertex-by-vertex
hope it's of help... :-)
-shane.
On Fri, 2011-01-07 at 12:49 +0200, Maris Nartiss wrote:
> Open a bug report with exact step-by-step how to reproduce this issue.
> http://trac.osgeo.org/grass
> Maris.
> 2011/1/7, Shane Litherland <litherland-farm at bigpond.com>:
> > Hi again,
> > another little thing I found by accident,
> > If digitising boundaries, then using 'remove vertex' to delete some of a
> > boundary, vertex-by-vertex... If I kept going and removed all the
> > vertexes (instead of the correct way of using 'delete
> > point/line/boundary'), it was possible to end up with some leftovers..
> > I could see a lone red cross on the v.digit screen (meaning, node(1
> > line) ) that I could not select to move, add, delete, anything... no
> > matter what my zoom.
> > This errant node did not show in the GRASS map view of the vector in
> > question, only in v.digit.
> > Using v.clean 'found' and removed this errant node (using the rmline
> > option) and I checked the vector info of the 'dirty' versus 'clean'
> > vectors to see nothing else had been upset.
> > It was an accident, I thought I'd selected the 'delete' tool...
> > but interesting, nonetheless ;-)
> > regards,
> > shane.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
