[GRASS-user] leftover node in v.digit
Shane Litherland
litherland-farm at bigpond.com
Sun Jan 9 19:55:35 EST 2011
Hi Maciek,
Just looking into newer version/s. Appreciate comment. I check the
standard ubuntu stable reps for versions, RC6 has been hanging in there
for a while... I generally have stuck with those ubuntu-reps versions
for ease-of-use etc, but will see what I can get from 'unstable' (seems
6.4.0-2 is an option) or, manually upgrade GRASS to on my box. Alas,
when I set this box up early 2010, the consensus seemed to be to stick
with 32-bit unless I really needed 64-bit... now GRASS 6.4.1 is only (?)
in 64-bit on the link you gave, so I'll either resort to the next-best
32-bit that I can find... or tackle the small drama of reinstalling
64-bit on my box... at the moment, the former is easier, but I know, I
know, at some point I'll have to be dragged kicking and screaming to
64-bit ;-)
... I could probably wade through compiling from source to get 6.4.1 as
32-bit if it's available but i'd be stretching my computing skills there
too..
Regards,
Shane.
On Sun, 2011-01-09 at 20:39 +0100, Maciej Sieczka wrote:
> W dniu 08.01.2011 06:01, Shane Litherland pisze:
> >>> Hi Maris,
> >>> Have braved my first attempt at filing a bug report, and appear
> >>> to have put enough together to generate a ticket
> >>> Ticket #1256 leftover node when deleting boundaries
> >>> vertex-by-vertex
> >>> hope it's of help... :-)
> >> 2011/1/9, Maciej Sieczka <msieczka at sieczka.org>:
> > Shane,
> > 6.4.0 RC6 is several months old.
> > Please try installing and veryfing your issues against the newest
> > stable release candidate -
> > http://grass.osgeo.org/grass64/binary/linux/snapshot/.
> > If impossible, please at least try the 6.4.0 final Ubuntu package
> > from https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable/.
> W dniu 09.01.2011 19:00, Maris Nartiss pisze:
> > Hello Maciek, it wouldn't change a lot, as this bug is also present
> > in 6.5. It's just a corner case. Nobody has been doing such strange
> > thing before and thus it has went unnoticed for years.
> > Shane, thanks for report. I will fix it someday (hopefully for
> > 6.4.2).
> Shane,
> FWIW - I was referring to reporting an testing habbits in general :).
> Maciek
