[GRASS-user] leftover node in v.digit
Shane Litherland litherland-farm at bigpond.com
Sun Jan 9 18:50:43 EST 2011
trust me to do something strange with otherwise healthy software ;-)
... that dangerous stage where I think I know enough to use it but don't
really (i.e. brashly clicking on tool icons without checking what tool
i've clicked on...)
Regards,
Shane.
On Sun, 2011-01-09 at 20:00 +0200, Maris Nartiss wrote:
> Hello Maciek,
> it wouldn't change a lot, as this bug is also present in 6.5. It's
> just a corner case. Nobody has been doing such strange thing before
> and thus it has went unnoticed for years.
> Shane, thanks for report. I will fix it someday (hopefully for 6.4.2).
> Maris.
> 2011/1/9, Maciej Sieczka <msieczka at sieczka.org>:
> > W dniu 08.01.2011 06:01, Shane Litherland pisze:
> >> Hi Maris,
> >> Have braved my first attempt at filing a bug report, and appear to have
> >> put enough together to generate a ticket
> >> Ticket #1256
> >> leftover node when deleting boundaries vertex-by-vertex
> >> hope it's of help... :-)
> > Shane,
> > 6.4.0 RC6 is several months old.
> > Please try installing and veryfing your issues against the newest stable
> > release candidate - http://grass.osgeo.org/grass64/binary/linux/snapshot/.
> > If impossible, please at least try the 6.4.0 final Ubuntu package from
> > https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable/.
> > Maciek
> >> -shane.
> >> On Fri, 2011-01-07 at 12:49 +0200, Maris Nartiss wrote:
> >>> Open a bug report with exact step-by-step how to reproduce this issue.
> >>> http://trac.osgeo.org/grass
> >>> Maris.
> >>> 2011/1/7, Shane Litherland<litherland-farm at bigpond.com>:
> >>>> Hi again,
> >>>> another little thing I found by accident,
> >>>> If digitising boundaries, then using 'remove vertex' to delete some of a
> >>>> boundary, vertex-by-vertex... If I kept going and removed all the
> >>>> vertexes (instead of the correct way of using 'delete
> >>>> point/line/boundary'), it was possible to end up with some leftovers..
> >>>> I could see a lone red cross on the v.digit screen (meaning, node(1
> >>>> line) ) that I could not select to move, add, delete, anything... no
> >>>> matter what my zoom.
> >>>> This errant node did not show in the GRASS map view of the vector in
> >>>> question, only in v.digit.
> >>>> Using v.clean 'found' and removed this errant node (using the rmline
> >>>> option) and I checked the vector info of the 'dirty' versus 'clean'
> >>>> vectors to see nothing else had been upset.
> >>>> It was an accident, I thought I'd selected the 'delete' tool...
> >>>> but interesting, nonetheless ;-)
> >>>> regards,
> >>>> shane.
> >>>> _______________________________________________
> >>>> grass-user mailing list
> >>>> grass-user at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> > Maciej Sieczka
> > http://www.sieczka.org
