[GRASS-user] problem with g.extension
Eduardo Klein eklein at usb.ve
Wed Jan 12 12:23:33 EST 2011
Thanks, you're right. But still, after installing the missing package
and fixing some permissions problems, I'm getting some errors. The first
of them:
make[82]: Entering directory
`/home/eklein/grassdata/usb/PERMANENT/.tmp/diodon/7414.0/v.mkhexgrid'
if [
"/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/scripts/v.mkhexgrid"
!= "" ] ; then
GISRC=/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/demolocation/.grassrc64
GISBASE=/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu
PATH="/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/bin:$PATH"
LD_LIBRARY_PATH="/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/bin:/build/buildd/grass-6.4.0/dist.i486-pc-linux-gnu/lib:/usr/lib/grass64/lib"
LC_ALL=C fakeroot
--html-description < /dev/null | grep -v '</body>\|</html>' >
v.mkhexgrid.tmp.html ; true ; fi
ERROR: G_getenv(): Variable LOCATION_NAME not set
Any ideas?
Saludos, EKS
On 01/12/2011 11:57 AM, Martin Landa wrote:
> 2011/1/12 Eduardo Klein<eklein at usb.ve>:
>> I'm on ubuntu 10.04, grass 6.4 and my $GISBASE is /usr/lib/grass64
>> The directory /usr/lib/grass64/include/Make/ does exists (but it is empty).
> missing grass-dev package.
> Martin
Eduardo Klein
Lab Sensores Remotos e
Instituto de Tecnología y Ciencias Marinas
Universidad Simón Bolívar
Caracas, Venezuela
ph (58) (212) 906-3111 ext 6700
fax (58) (212( 906-3111 ext 6701
