[GRASS-user] Re: Generate variograms from landsat data
Stefan
fabiosela at gmx.de
Tue Jan 18 23:51:08 EST 2011
Chethan,
as far as I know you have to use the GRASS-R interface to do variograms.
Have a look at http://casoilresource.lawr.ucdavis.edu/drupal/node/438
This tutorial is only for the use of vector point data, but maybe it can
help you for your raster-map issue.
I used this tutorial to do some variograms myself with the GRASS-R
interface. It worked quiet well, I can only recommend it.
All the best-
Stefan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Generate-variograms-from-landsat-data-tp5934843p5938312.html
Sent from the Grass - Users mailing list archive at Nabble.com.
