[GRASS-user] Accessing GRASS databases from Python
Joshua Arnott josh at snorfalorpagus.net
Thu Jan 20 13:52:23 EST 2011
Hi grass-users,
I'd like to find out what is the best way of accessing a pre-connected
database in GRASS from a Python script. I can see a few different
possible approaches to this, but I'm not sure which to take. Ultimately,
I want to be able to do two different tasks:
1) Change data for a row, or rows, in one column based on the values of
other columns in the same row(s). Similar to v.db.update qcolumn=???,
but I'd like to do the calculations in Python so I have a bit more
freedom (accessing existing functions, etc).
2) Calculate statistics based on the content of all, or some (based on
an SQL where statement), of the rows from a column in a table. For (a
very simplistic) example, calculate the mean from a list of values in a
'temperature' column.
What is the best way to get this information into a manageable form in
Python?
I'm running GRASS 6.4.1RC1 on OS X, as compiled by:
http://www.kyngchaos.com/
If I could guarantee the database would be in a certain format (DBF,
SQLite, etc) I could just use Pythons respective libraries, but that
doesn't seem very portable. I've had a look at the database functions in
the grass.script.db python library, but haven't had any luck getting the
db_select function to work. In the default install, the function didn't
even exist in db.py. I've added it, based on the current source, but all
I get out is:
 >>> grass.script.db.db_select('Population_Density','select * from
Population_Density')
Sorry, <output> is not a valid parameter
Any wisdom would be appreciated.
Josh.
