[GRASS-user] Accessing GRASS databases from Python
Glynn Clements
glynn at gclements.plus.com
Thu Jan 20 20:58:35 EST 2011
Joshua Arnott wrote:
> I've had a look at the database functions in
> the grass.script.db python library, but haven't had any luck getting the
> db_select function to work. In the default install, the function didn't
> even exist in db.py. I've added it, based on the current source, but all
> I get out is:
> >>> grass.script.db.db_select('Population_Density','select * from
> Population_Density')
> Sorry, <output> is not a valid parameter
That parameter was added in 7.0. The 6.x version of db.select always
writes to stdout.
You can just run db.select using grass.script.pipe_command(), e.g.:
import grass.script as grass
ps = grass.pipe_command(
'db.select',
quiet = True,
flags = 'c',
table = table,
sql = sql)
for line in ps.stdout:
fields = line.strip().split('|')
ps.wait()
