[GRASS-user] r.reclass.area...aborted
Gabriele N.
gis.gn at libero.it
Fri Jan 21 15:28:27 EST 2011
Ciao grass users.
I have a warning when I launch the command r.reclass.area........aborted.
The map, however, is generated but I'm not sure that everything is correct.
What do you say?
Thanks
r.reclass.area
input=fc_map_1001_int_fl1_NO_6_bin_fl2fl1ec_recode_meno_10_11___15
output=fc_map_1001_int__min_10pix lesser=62.5
Generating a clumped raster map...
Pass 1...
Pass 2...
r.clump completo. 186967 clumps.
Generating a reclass rules file with area size less than or equal to 62.5
hectares...
Generating output raster map <fc_map_1001_int__min_10pix>...
Aborted
(Fri Jan 21 21:02:34 2011) Comando terminato (197 sec)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-reclass-area-aborted-tp5949232p5949232.html
Sent from the Grass - Users mailing list archive at Nabble.com.
