[GRASS-user] Re: batch conversion of ESRI to MapInfo
Hermann Peifer
peifer at gmx.eu
Sat Jan 29 06:48:51 EST 2011
> ogr2ogr -f "MapInfo File" mapinfo/$file.tab $file
You could cut away the "shp" suffix like this:
ogr2ogr -f "MapInfo File" mapinfo/${file%shp}tab $file
I am not fully sure what "real world co-ordinates" means, but this
additional switch might do what you expect:
-t_srs epsg:4326
Hermann
On 29/01/2011 10:53, Saber Razmjooei wrote:
> Mik
> As suggested, better to use ogr2ogr.
> if you use linux:
> 1- Create an empty text file in the folder where your shapefiles are
> located
> 2- Open the text file and copy paste these:
> mkdir ./mapinfo
> for file in *.shp
> do
> done
> 3-save the file as convert.sh
> 4- from the terminal, run convert.sh
> $ cd /PATH/TO/SHAPEFILES/
> $ sh convert.sh
> 5- all your mapinfo files should appear under mapinfo folder.
> Cheers
> Sab
