[GRASS-user] Using v.colors in WinGRASS
Markus Neteler
neteler at osgeo.org
Sun Jan 30 08:18:57 EST 2011
On Wed, Nov 10, 2010 at 11:39 AM, Hamish <hamish_b at yahoo.com> wrote:
>> try r44284, hopefully fixed.
> perhaps buggy:
> - CMDLINE="`basename $0`"
> + CMDLINE="`basename "$0"`"
> becomes "`basename " + $0 + "`"
> afair the " do not nest.
> maybe outer quotes are not needed?
> (but regardless I'm fairly sure this is not the cause of the v.colors bug, just a red herring)
For the record:
Fixed in r45247 (6.4) and r45248 (6.5) with only the inner quotes:
CMDLINE=`basename "$0"`
Tested successfully for v.in.geonames. This should also fix odd wxGUI/XML
errors.
Markus
