[GRASS-user] r.in.gdal worldclim-data - G_set_window(): geographic
latitude not valid for north
Helmut Kudrnovsky
hellik at web.de
Sun Jan 30 12:55:42 EST 2011
I have an esri binary grid from http://www.worldclim.org/formats in wgs84/ll
gdalinfo (gdal18)
Driver: AIG/Arc/Info Binary Grid
Files: prec_1
prec_1.ovr
prec_1.aux.xml
prec_1\dblbnd.adf
prec_1\hdr.adf
prec_1\log
prec_1\metadata.xml
prec_1\prj.adf
prec_1\sta.adf
prec_1\vat.adf
prec_1\w001001.adf
prec_1\w001001x.adf
Size is 43200, 18000
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000007823109627)
Pixel Size = (0.008333333767951,-0.008333333767951)
Corner Coordinates:
Upper Left (-180.0000000, 90.0000078) (180d 0' 0.00"W, 90d 0' 0.03"N)
Lower Left (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
Upper Right ( 180.0000188, 90.0000078) (180d 0' 0.07"E, 90d 0' 0.03"N)
Lower Right ( 180.0000188, -60.0000000) (180d 0' 0.07"E, 60d 0' 0.00"S)
Center ( 0.0000094, 15.0000039) ( 0d 0' 0.03"E, 15d 0' 0.01"N)
Band 1 Block=256x4 Type=Int16, ColorInterp=Undefined
Description = prec_1
Min=0.000 Max=1003.000
Minimum=0.000, Maximum=1003.000, Mean=53.000, StdDev=77.000
NoData Value=-32768
Overviews: 21600x9000, 10800x4500, 5400x2250, 2700x1125, 1350x563, 675x282, 338x141
Metadata:
STATISTICS_MINIMUM=0
STATISTICS_MAXIMUM=1003
STATISTICS_MEAN=53,870989116945
STATISTICS_STDDEV=77,56242554647
the grass-location is following
g.region -p
projection: 3 (Längen- und Breitengrad)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 35N
south: 0
west: 0
east: 35E
nsres: 1
ewres: 1
rows: 35
cols: 35
cells: 1225
if I want to import the esri binary grid with r.in.gdal, I get following message
r.in.gdal -e input=C:\data\BIOCLIM\prec_201101_ersigrid\prec_30s_esri\prec\prec_1\hdr.adf output=prec1
Projection of input dataset and current location appear to match
G_set_window(): Ungültige geographische Breite für Norden.
G_set_window(): geographic latitude not valid for north.
if I do r.in.gdal -l
r.in.gdal -l --verbose input=C:\data\BIOCLIM\prec_201101_ersigrid\prec_30s_esri\prec\prec_1 output=prec1
Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map
bounds and resolution with r.info and reset them with r.region before going any further.
Proceeding with import...
r.in.gdal komplett. Raster map <prec1> created.
| Layer: prec1 at data Date: Sun Jan 30 18:45:35 2011 |
| Mapset: data Login of Creator: syringia |
| DataBase: C:\gisdata\grassdata |
| Title: ( prec1 ) |
| Timestamp: none |
| Type of Map: raster Number of Categories: 1003 |
| Data Type: CELL |
| Rows: 18000 |
| Columns: 43200 |
| Total Cells: 777600000 |
| Projection: Längen- und Breitengrad |
| N: 90N S: 60S Res: 0:00:30 |
| E: 179:59:59.932408W W: 180W Res: 0:00:00.000002 |
| Range of data: min = 0 max = 1003 |
| Data Description: |
| generated by r.in.gdal |
| Comments: |
| r.in.gdal -l input="C:\data\BIOCLIM\prec_201101_ersigrid\prec_30s_es\ |
| ri\prec\prec_1" output="prec1" |
what would be the best way to get this raster into a wgs84-ll-location?
maybe to crop the raster a little bit by gdaltranslate?
any hints?
best regards
Helmut
___________________________________________________________
Neu: WEB.DE De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
Jetzt De-Mail-Adresse reservieren: https://produkte.web.de/go/demail02
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110130/c464b62e/smime.bin
