[GRASS-user] r.in.gdal worldclim-data - G_set_window():
	geographic latitude not valid for north
    Markus Metz
    markus.metz.giswork at googlemail.com
    Sun Jan 30 13:34:35 EST 2011
On Sun, Jan 30, 2011 at 6:55 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Hi,
> I have an esri binary grid from http://www.worldclim.org/formats in wgs84/ll
I had the same problem with a worldclim raster.
I can see two possibilities to get it import ito wgs84/ll
1) quick and easy, but maybe not correct with r.in.gdal -l
2) the hard way
Assume a precision loss somewhere in the creation of the esri binary
grid. I assume that the (ESRI) software used to create these rasters
uses single and not double precision for extends, resolution, center
coordinates etc.
Assume that the bounds are supposed to be
North: 90
South -60
East: 180
West: -180
and not
North: 90.0000078
South -60
East: 180
West: -180.0000188
More on, assume that pixel size should be exactly 00:05:00 or
0.008333333333333 and not 0.008333333767951 and that the number of
rows and cols is correct.
The assumed correct extends and resolution, preserving the grid
dimensions (rows, cols) would be
North: 90
South -60
East: 180
West: -180
res: 00:05:00
I don't know where this information is stored in an Arc/Info Binary
Grid, but this is easy to edit with a text editor in an ESRI hdr (GDAL
EHdr diver) labelled grid created with gdal_translate. The adjusted
EHdr raster should then import correctly without the -l switch. Maybe
gdal_translate -a_ullr to "Assign/override the georeferenced bounds of
the output file" can help too.
HTH,
Markus M
> gdalinfo (gdal18)
> Driver: AIG/Arc/Info Binary Grid
> Files: prec_1
>  prec_1.ovr
>  prec_1.aux.xml
>  prec_1\dblbnd.adf
>  prec_1\hdr.adf
>  prec_1\log
>  prec_1\metadata.xml
>  prec_1\prj.adf
>  prec_1\sta.adf
>  prec_1\vat.adf
>  prec_1\w001001.adf
>  prec_1\w001001x.adf
> Size is 43200, 18000
> Coordinate System is:
> GEOGCS["WGS 84",
>  DATUM["WGS_1984",
>  SPHEROID["WGS 84",6378137,298.257223563,
>  AUTHORITY["EPSG","7030"]],
>  TOWGS84[0,0,0,0,0,0,0],
>  AUTHORITY["EPSG","6326"]],
>  PRIMEM["Greenwich",0,
>  AUTHORITY["EPSG","8901"]],
>  UNIT["degree",0.0174532925199433,
>  AUTHORITY["EPSG","9108"]],
>  AUTHORITY["EPSG","4326"]]
> Origin = (-180.000000000000000,90.000007823109627)
> Pixel Size = (0.008333333767951,-0.008333333767951)
> Corner Coordinates:
> Upper Left  (-180.0000000,  90.0000078) (180d 0' 0.00"W, 90d 0' 0.03"N)
> Lower Left  (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
> Upper Right ( 180.0000188,  90.0000078) (180d 0' 0.07"E, 90d 0' 0.03"N)
> Lower Right ( 180.0000188, -60.0000000) (180d 0' 0.07"E, 60d 0' 0.00"S)
> Center      (   0.0000094,  15.0000039) (  0d 0' 0.03"E, 15d 0' 0.01"N)
> Band 1 Block=256x4 Type=Int16, ColorInterp=Undefined
>  Description = prec_1
>  Min=0.000 Max=1003.000
>  Minimum=0.000, Maximum=1003.000, Mean=53.000, StdDev=77.000
>  NoData Value=-32768
>  Overviews: 21600x9000, 10800x4500, 5400x2250, 2700x1125, 1350x563, 675x282, 338x141
>  Metadata:
>  STATISTICS_MINIMUM=0
>  STATISTICS_MAXIMUM=1003
>  STATISTICS_MEAN=53,870989116945
>  STATISTICS_STDDEV=77,56242554647
> the grass-location is following
> g.region -p
> projection: 3 (Längen- und Breitengrad)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      35N
> south:      0
> west:       0
> east:       35E
> nsres:      1
> ewres:      1
> rows:       35
> cols:       35
> cells:      1225
> if I want to import the esri binary grid with r.in.gdal, I get following message
> r.in.gdal -e input=C:\data\BIOCLIM\prec_201101_ersigrid\prec_30s_esri\prec\prec_1\hdr.adf output=prec1
> Projection of input dataset and current location appear to match
> G_set_window(): Ungültige geographische Breite für Norden.
> G_set_window(): geographic latitude not valid for north.
> if I do r.in.gdal -l
> r.in.gdal -l --verbose input=C:\data\BIOCLIM\prec_201101_ersigrid\prec_30s_esri\prec\prec_1 output=prec1
> Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map
> bounds and resolution with r.info and reset them with r.region before going any further.
> Proceeding with import...
> r.in.gdal komplett. Raster map <prec1> created.
>  | Layer:    prec1 at data                     Date: Sun Jan 30 18:45:35 2011    |
>  | Mapset:   data                           Login of Creator: syringia        |
>  | Location: wgs84llwc                                                        |
>  | DataBase: C:\gisdata\grassdata                                             |
>  | Title:     ( prec1 )                                                       |
>  | Timestamp: none                                                            |
>  |   Type of Map:  raster               Number of Categories: 1003            |
>  |   Data Type:    CELL                                                       |
>  |   Rows:         18000                                                      |
>  |   Columns:      43200                                                      |
>  |   Total Cells:  777600000                                                  |
>  |        Projection: Längen- und Breitengrad                                 |
>  |            N:        90N    S:        60S   Res: 0:00:30                   |
>  |            E: 179:59:59.932408W    W:       180W   Res: 0:00:00.000002     |
>  |   Range of data:    min = 0  max = 1003                                    |
>  |   Data Description:                                                        |
>  |    generated by r.in.gdal                                                  |
>  |   Comments:        |
>  |    r.in.gdal -l input="C:\data\BIOCLIM\prec_201101_ersigrid\prec_30s_es\   |
>  |    ri\prec\prec_1" output="prec1"                                          |
> what would be the best way to get this raster into a wgs84-ll-location?
> maybe to crop the raster a little bit by gdaltranslate?
> any hints?
> best regards
> Helmut
> ___________________________________________________________
> Neu: WEB.DE De-Mail - Einfach wie E-Mail, sicher wie ein Brief!
> Jetzt De-Mail-Adresse reservieren: https://produkte.web.de/go/demail02
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
