[GRASS-user] replacement for d.mon in GRASS 7.0?
Rainer M Krug r.m.krug at gmail.com
Mon Jan 31 04:15:27 EST 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 01/29/2011 06:36 AM, Glynn Clements wrote:
> Rainer M Krug wrote:
>> I just started using d.mon in combination with d.rast to quickly display
>> a layer - but d.mon will be removed in 7.0. I assume there is a
>> replacement for it, which I can use in 7.0? I do not assume, that I have
>> to use GUI for display.
> You can use wxpyimgview[1] to view the images.
> [1] or wximgview or ximgview. ximgview is C/Xlib, wximgview is
> C++/wxWidgets, wxpyimgview is Python/wxWidgets.
> For this, you need:
> 	export GRASS_PNG_MAPPED=TRUE
> Optionally:
> 	export GRASS_NOTIFY='kill -USR1 <pid>'
> where <pid> is the PID of the {x,wx,wxpy}imgview process. This allows
> you to set percent=0; the display will be redrawn whenever a display
> command completes.
Thanks - looks interesting. I'll look into that.
As I am doing quite straight forward GIS stuff, I might try 7.0 and see
how it goes.
Thanks,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Natural Sciences Building
Office Suite 2039
Stellenbosch University
Main Campus, Merriman Avenue
Stellenbosch
South Africa
Tel:        +33 - (0)9 53 10 27 44
Cell:       +27 - (0)8 39 47 90 42
Fax (SA):   +27 - (0)8 65 16 27 82
Fax (D) :   +49 - (0)3 21 21 25 22 44
Fax (FR):   +33 - (0)9 58 10 27 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk1Gfa8ACgkQoYgNqgF2egrrZACfWEmgG3AIoBmAOjYK1p+UqgU+
QloAmwXKFL0TrMck5AtxwBfguS7bd1HI
=qKSj
-----END PGP SIGNATURE-----
