[GRASS-user] Re: Shapefile to Surface
leonidas
leonidas_liakos at yahoo.gr
Mon Jan 31 15:29:37 EST 2011
Markus thank you!
I used r.in.xyz according to your instructions.
I set the region as follow:
g.region -a res=150
And then r.in.xyz to generate the surface.
The points are not located in the center of the cells but on the upper left
corner. Is that a feature or I made a mistake with the region settings?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Shapefile-to-Surface-tp5977485p5978538.html
Sent from the Grass - Users mailing list archive at Nabble.com.
