[GRASS-user] Exporting labels of a raster
Rainer M Krug
r.m.krug at gmail.com
Fri Jul 1 07:54:45 EDT 2011
On Fri, Jul 1, 2011 at 1:24 PM, Luisa Peña <luisapena1979 at gmail.com> wrote:
> It didn't work. I get all full of NaNs map.
> I used this:
> input="LUlabel at Study"
> grass.run_command("g.region", rast = input)
> grass.mapcalc("$output= @$labels", labels=input, output="Giovanni2")
> What am I doing wrong on this?
NaN means Not a Number - were your labels non-numeric?
I *think* that raster can only have numeric cell values
Rainer
> Luisa
> 2011/7/1 Giovanni Manghi <giovanni.manghi at gmail.com>
>> Hi,
>> > I have a raster map to wich I have applied r.reclass to add labels to
>> > raster classes. When I try to export this raster with the classes I
>> > loose the lablels I only stick with the values.
>> > In a script how can edit this raster in order to be exported with the
>> > labels?Thanks
>> r.mapcalc "new_map=@existing_map"
>> then export "new_map" to tiff as usual.
>> Cheers
>> -- Giovanni --
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110701/0bf3f16a/attachment.html
