[GRASS-user] wave energy model
Andy Wickert
wickert at colorado.edu
Sat Jul 2 04:31:10 EDT 2011
Some advice for getting / compiling SWAN:
You should definitely be able to build SWAN by yourself; it may take a
little while, but compiling code is a good skill to know. My best advice is
to slowly step through the directions (see the links that I gave you) to
first run the perl script to make the code settings right for your system
and then go through the actual compilation / installation. Google is also
your friend; chances are, if you search for something about a problem you
are having, someone else has had it too and the answer is online.
I'm not sure what mac comes with in terms of compilers / interpreters for
programming languages, so you may have to download a Fortran compiler and/or
Perl. I'm guessing that you'll have some version of Perl on your computer
already, but probably not Fortran (gfortran is good, as Hamish and I suggest
earlier). Same advice as above: when you're lost, Google is your friend.
Best of luck!
Andy
On Fri, Jul 1, 2011 at 3:30 AM, Salvatore Mellino <
salvatore.mellino at gmail.com> wrote:
> I have a problem with safari, but now I try to download files with firefox
> and it works. I download this file:
> US058GOCN-GR1mdl(1).0110_0240_00000F0RL2010010100_0001_000000-000000max_wav_ht.
> It is correct? This is the file for 01/01/201o the first on the list. I have
> to download 1 file for each day? I need a long term average/exposure (one
> year).
> Thanks for now...I have a lot things to learn.
> I don't know if I am able to build SWAN by my self, I'm not a programmer.
> Until one week ago I worked with ArcGis but now I want switch to opensource.
> Il giorno 01/lug/2011, alle ore 10.24, Hamish ha scritto:
> > Salvatore wrote:
> >> I'm not able to download any data from your links...
> > what's the error message?
> >> I never worked with these kind of data before.
> > now's your chance :)
> > gdal can read GRIB format directly, but due to a gdal bug you'll
> > have to apply a 1/2 cell correction after import with r.region.
> > did you want long-term average conditions/exposure or
> >> Than I would to know where I can find a good bathymetry.
> > I don't know of a good source in the Med. Maybe someone else
> > does? For global oceans the ETOPO1 dataset is great, but that's
> > not terribly useful near shore.
> > An approach of last resort is to digitize from nautical charts.
> > I usually prepare my model grid/bathy in GRASS then export with
> > r.out.ascii, it can read those files directly.
> > For MacOSX I guess you'll have to build SWAN yourself using a
> > fortran compiler. (GCC's gfortran is fine) Note SWAN likes lots
> > and lots of RAM.
> > Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110702/5221d6bf/attachment-0001.html
