[GRASS-user] divide a vector map in the display monitor.
Maris Nartiss
maris.gis at gmail.com
Sun Jul 3 07:49:20 EDT 2011
Hello,
why bother with d.split whatever - just render two separate pictures
(change GRASS_REGION for each of them) and join them afterwards within
Your Python script. Still it might get tricky, if extents of both of
those pictures isn't the same, still I hope You got the idea.
Maris.
http://grass.osgeo.org/grass64/manuals/html64_user/variables.html#internal
2011/7/1 Martin Album Ytre-Eide <Martin.Album.Ytre-Eide at nrpa.no>:
> Hello all!
> I am trying to divide a vector map of Norway in the display monitor (I am running a python script and using the png-driver). I have made to separeted vector files which I now wont to put next to each other.
> I have experimented with using d.frame and d.split.frame - but the results is not good. When doing a split the dimensions are lost? - when doing a horizontal split the "height" is set equal which in my case is not correct. When doing a vertical split , the "heigt" is preserved, but the width get messued up.
> I have attached a file which shows what I wont to do (except the island in the top left corner).
> Anyone knows how this should be done?
> Thanks!
> Martin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
