[GRASS-user] Re: [GRASS-dev] GRASS 7 vector topology format
changed
Daniel Lee
lee at isi-solutions.org
Sun Jul 3 16:58:28 EDT 2011
On Sun, Jul 3, 2011 at 6:54 PM, Markus Metz <
markus.metz.giswork at googlemail.com> wrote:
> On Fri, Jul 1, 2011 at 2:48 PM, <Doug_Newcomb at fws.gov> wrote:
> >>The new format offers new possibilities for the v.surf.* modules
> >>because it is now possible to build (parts of the) topology even for
> >>massive point clouds which in turn makes it possible to quickly
> >>perform spatial queries with very low memory consumption (a very few
> >>MB)
> > Markus,
> > By massive point clouds, do you mean greater than 4 Billion points? A
> good
> > long weekend for testing at home
> Ummh, no, 4 billion is probably a bit much. It would however require
> relatively little changes to support that amount of points...
That would be great if it wouldn't be a lot of work! I work with LiDAR
clouds and sometimes that's a TON of point data.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110703/62d61472/attachment.html
