[GRASS-user] Export coordinates of 3D line feature into csv
format?
Micha Silver
micha at arava.co.il
Fri Jul 8 07:16:28 EDT 2011
On Fri, 2011-07-08 at 11:19 +0200, Rainer M Krug wrote:
> Hi
> I would like to export a 3D line feature into a csv format, as in:
> x y z
> 1 2 3
> I am not interested in the attribute tab;e, as I need the coordinates
> incl z.
FIrst create attrib columns for the X-Y-Z values:
v.db.addcol <vectormap> col="x double precision, y double precision z
double predision"
Then put the values into those columns
v.to.db <vectormap> option=coor column="x,y,z"
Now export the attrib table as you did before.
> Is this possible? I only managed to export the attribute table so far
> (which I do not need...)
> Cheers,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
> Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel : +33 - (0)9 53 10 27 44
> Cell: +33 - (0)6 85 62 59 98
> Fax (F): +33 - (0)9 58 10 27 44
> Fax (D): +49 - (0)3 21 21 25 22 44
> email: Rainer at krugs.de
> Skype: RMkrug
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110708/2564780e/attachment.html
